Internal Error 002 - Fibers failing to connect
I am using Creo Schematics Release 11.0 and Datecode11.0.0.0
Check connections tool reports missing connection on one of my blocks. The fiber appears to be attached, but when trying to reattach, the line jumps to the bottom left corner of the screen and reports error Internal Error 002. The only work around I have found is completely deleting the fiber, and rerunning it, but this does not necessarily fix the missing connection error.
Check database reports no errors.
Here are the errors that I faced
>>>> error <<<<
Internal Error (002) occurred. Use the Check Database tool and contact technical support for assistance.
