Issue with Creating a Branch Bundle in Creo Cabling - Cannot Select the Second Point
Hi everyone,I am working on a cabling harness design in Creo Parametric. I successfully created a main bundle using the "Along Path" option. Now, I need to create a Branch Bundle that splits off to the right from this main thick bundle.When I select Bundle > Create > Branch, the Menu Manager asks me to "Select 2 items." and forces the selection filter strictly to "Location".However, when I try to select the required locations, it does not allow me to complete the selection or choose the second point correctly to define the branching direction along the network. The network paths for both the main trunk and the branches are already defined, and the wires are routed.Could someone please guide me on the exact selection sequence or share what might be blocking the second item selection in this step?
Catalina
Community Manager
Hi ​@E�_14419322
Thank you for your question. 
Catalina | PTC Community Manager
