Schematics 12 Datatable Development for FSAE
- 3 replies
- 456 views
- Translate All
I am trying to implement Creo Schematics and Parametric for my university's Formula SAE team.
Unfortunately I have issue loading the made .csv files back into Schematics.
Initially the Datatable csv was fine but now with the Membermap updated, it no longer uploads into Schematics.
Under the impression that the Type declared in the parameter of the wires I initially used was the issue, I tried to adjust the $$$datasettype$$$ value of the Datatable to different forms, referencing other wire types but this was not the issue still.
I've attached the two Excel files I've put together to this message In hopes someone might understand where issues are arising. As well, here is a link to my original post in case that might be beneficial.
I will be working on putting together a datatable set for the connectors (Mostly Deutsch) as to ensure that Creo will be set up far enough that auto-routing is possible even I don't manage to implement it for our Vehicle's CAD, this final semester of my Bachelor degree program.
I am looking forward to learning more about Creo's capabilities and rules. 😅
Thank you for your time.
