VISUALIZATION OF COMBINED STATES CREO VIEW 6.0
Hello to all,
I am trying to export a Creo Parametric assembly to pvz which contains annotations both at the assembly and part level.
I noticed that if I save the annotations in combined states they are exported to pvz and I display them in Creo View 6.0.
However, the combined states of the assembly are exported by themselves, but not the parts.
Is there any chance to do this?
Thank you,
Matteo.
vdegaonkar
Translation in English:
Hello to all,
I am trying to export a Creo Parametric assembly to pvz which contains annotations both at the assembly level and at the part level.
However, only the combined states of the assembly are exported, but not the parts.
Thank you,
Matteo.
vdegaonkar
Annotations owned by root & all child component are converted always. Where as conversion of view states (Combined State) is supported for root level component only. Child component's view state conversion is not support.
6-Contributor
Hello to all,
when opening . prt files directly in Creo View, it is possible to display the Combined States without exporting from Creo Parametric via . pvs files?
Is there a . rcp file that is attracted when I open Creo Parametric files directly in Creo View?
 . pvs files.
Thank you,
Sascha
vdegaonkar
Direct loading of Creo Parametric file (part\assembly) does load only graphical content of Creo File. It does not support conversion & viewing of Combined States.
To convert Combined States from Creo Parametric to Creo View format:
  • From Creo Parametric call File -> SaveAs -> Creo View (PVZ).
  • Or use Creo View Adapter for Creo Parametric and export using Publish or Batch mode.
However, I have not found a way to export the combined states within a part.
As I said in the first place only those of the assembly are exported.
Matteo.
