Add Menu to ProductView Context Menu
  • October 7, 2010
  • 0 replies
  • 1296 views
I'm using the ProductView API M030 - In the documentation of M030 the description of how to implement a menu item in the ProductView context menu is missing. So here is the how to:
In your actor you have to add a method to hande the menu item:
public void manageMenuItemEvent (MenuItemEvent ev )
        ManageObject (ev.GetMenuItemIf());
I have an class where i put all the basic function of the api (pvStdManager). There i have a method that adds the menu item to the world object and call the prior method in the actor:
public static void addMenu (MenuItemEvent menuEvent)
        try {
            //manage the menu item in your actor
            stdActor.manageMenuItemEvent(menuEvent);
            //add your menu item to the world object
            theWorld.AddMenuItem(menuEvent.GetMenuItemIf());
        } catch (Exception ex) {
            Logger.getLogger(pvStdManager.class.getName()).log(Level.SEVERE, null, ex);
The method is staic so you can acess it from everywere in your code. There you have to create a class (i have made a subclass) that extends com.ptc.pview.pvkapp.MenuItemEvent:
       private class ProeMenuItemEvent extends com.ptc.pview.pvkapp.MenuItemEvent {
        ProeMenuItemEvent() {
            super("Enter Menu Text here", 0);
        public void OnDoCommand() {
            // do something
I like the Idea of Conext menus so i am happy to use that function.
