3-Newcomer
November 1, 2014
Add option in PDF export to convert shaded graphics to shaded VECTOR graphic objects, NOT only raster pics
  • November 1, 2014
  • 4 replies
  • 3000 views
Currently PDF export in Creo Parametric saves all shaded graphics in raster.
For DRAWINGs, to get "shaded" PDFs with VECTOR graphics, you need to set to non-shaded view displays (ie: NO HIDDEN) and manually fill (Layout>>Hatch/Fill) and color individual feature surfaces one by one. This is tedious and time consuming.
There should be an export OPTION to directly convert shaded views (in ALL modes; ie: ASSEMBLY, PART and DRAWING) into VECTOR graphics with shaded/rendered areas as distinct FILLED OBJECTS in the assigned part colors with lighting gradients.
Furthermore, this vectorizing option should be given to all vector capable export formats (eg: *.DWG) and more vector graphics export formats should also be added (eg: *.ai from Adobe Illustrator).
Creo Parametric 2.0 is able to export text as TEXT, if you configure it to use TrueType fonts in drawings.
3-Newcomer
November 3, 2014
My bad. You are right. I have updated my submission accordingly. Thanks.
3-Newcomer
November 4, 2014
Amended my post again. This time, I added the work around I managed to come up with to get vector "shaded" objects.
Emeritus
June 14, 2018
