Can Creo Illustrate open native Creo Parametric files such as assmblies, parts and drawings?
  • July 15, 2024
  • 4 replies
  • 1164 views
All,
Or does and export file need to be created in Creo Parametrics such as Step?
Wayne
Community Moderator
July 19, 2024
Hello @wfalco,
It looks like you have a response from a community member. If it helped you solve your question please mark the reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
@wfalco You cannot directly open a Creo Parametric model in Creo Illustrate. Instead you need to use the Import so it will create a .c3di file from the Creo Parametric model.
If you use Windchill then I would highly recommend using Import, Link.
wfalco16-PearlAuthor
I'm confused. I go another response to my question saying native files can be opened?
