18-Opal
February 25, 2013
contour sets in Isodraw
  • February 25, 2013
  • 2 replies
  • 1553 views
In Isodraw how many contour sets can you have. I add two sets, give them different shades of grey. And only one ever shows up.
Bryon
Hi Bryon,
Contour sets work in a similar way to layers. Create all of your contour sets first with the corresponding colours. NOTE: Only one contour set is active at a time. You must first select the contour set you want to apply so that a red dot appears adjacent to that contour set. Then you in the 3D window, right-click an object and choose "selection to active contour set"
As for limitations, I can't answer that question but I would presume that you could have a fair number of sets available.
Hope this helps.
With kind regards,
Rick
bfriesen18-OpalAuthor
18-Opal
March 1, 2013
Thanks for the response Rick, it seems that after a restart, things were acting as they should. I was able to create two different contour sets with different shades of grey. There are some issues with it still if you have more that one assembly in a file with both having multiple contour sets.
thanks
Bryon
