7-Bedrock
June 1, 2024
Creo Schematics 7.0 - PDF export issue compare to CS 3.0
  • June 1, 2024
  • 713 views
I am using Creo Schematics Release 7.0 and Datecode7.0.0.0
There is an issue we are facing during PDF export from CS 7.0 compared to previous version CS 3.0 (used before CS 7.0) as mentioned. (i) The exported PDF from CS 7.0 and open in Adobe Illustrator for edit text properties is automatically changing the TEXT format into DARFT format. Please refer attachment for more details. (ii) The exported PDF from CS 7.0 (15MB) file size is 3 to 5 times larger than CS 3.0 (3MB). We just wonder why this drastic file size difference from older to newer versions. Sometime, it is taking more than 5 minutes to create the PDF file on CS 7.0. We used to color the circuit/wire name based on the functionality in Adobe Illustrator (AI). For formatting in Adobe Illustrator (AI), we use the PDF file exported from the RSD file saved from Creo Schematics. We do not face any issues in the older version of Creo Schematics (CS 3.0). After we deployed CS 7.0, the exported PDF file is selectable as a "TEXT (single word)" in PDF format. When we import into Adobe Illustrator (AI), the "TEXT (single word)" becomes "STROKE (single letter)" format. Current usage and version CS 7.0 F000 and Ai 28.4.1. Already posted in the PTC community but no solution yet.
Here are the errors that I faced
PDF export is not helping the used to format the word/wire name. single word converted as individual broken text. The text also changed to stroke
    Community Moderator
    June 6, 2024
    Hi Ramesh_Mani,
    Thank you for your question.
    I’d like to recommend to bring more details and context to your initial inquiry.
    It also helps to have screenshot(s) to better understand what you are trying to do in your process.
    Community Moderation Team.
