Creo Sketch - free sketching app
  • July 15, 2011
  • 20 replies
  • 7822 views
Paul Sagar, Director of Product Management for Creo at PTC, demonstrates  the key capabilities of Creo Sketch. Creo Sketch is PTC's 2D design app  for quickly drawing or sketching ideas- as easy as sketching on a  napkin. Add color, special effects, and text to turn a sketch into a  full 2D concept. Directly leverage sketches into other apps from PTC's  Creo suite of design software to turn 2D artwork into 3D models.
Will you download this free app when it becomes available?
Paul,
     Seems to be a missing link to the example. Is it the same video that Dan posted with the vacuum, or is it the one showing the creation of the mirror based on the output from the sketch app?
-Greg
Where can we downoad CREO Sketch from ?
Creo Sketch is now available and can now be downloaded for free below.
www.ptc.com/go/sketch
Paul
Thanks, Paul!
I don't necessarily need this tool to be parametric, but the apparent absence of a "export to .sec" (or something similar) seems like a big miss.
I try to print in Creo Sketch 1.0 file in PDF, but in the process of creating a file error occurs. Any ideas?
Vladimir, what are you using to print to PDF?
Paul, hello!
To print a PDF file, I used the printer "Adobe PDF" (I have installed the latest version of Adobe Reader X (10.1.0)). Log error is attached below.
Thanks.
http://communities.ptc.com/servlet/JiveServlet/download/167497-29335/MyDoc.log.zip
Vladimir
We are looking into this issue and will pix it in the next release
Paul
