Creo View 3.0 printing problem
  • February 9, 2015
  • 6 replies
  • 4053 views
Dear all,
On some workstations, Creo View 3 does not print DRW files. The strange thing is that 3D models can be printed without any problems. Does anyone encountered this issue and perhapse have an idea to solve this?
Thanks in advance!
Michiel
2-Explorer
February 20, 2015
Do you mean, nothing happens, an error is displayed, the printed output is incorrect or Creo View exits? And is it really "certain workstations" or rather "certain drawings"?
Our database lists an issue where Creo View exited - otherwise some more details (e.g. error message) may help triggering ideas.
CS180538 : Creo Parametric 3.0 exits randomly when trying to print drawing
msteenweg1-VisitorAuthor
Hi Gunter,
Creo view does not exit and does not give an error as well. Nothing happens when you give de command to print. Really strange. Maybe, it has something to do with the video card.
Michiel
We had a problem where most computers could print from Creo View but there were some that could not.  I found an old post saying they found that setting an environment variable fixed it.  I tried it and it worked.
Create a .vbs file with the following:
option explicit
dim shell, objEnv, userName, userVar
Set shell = CreateObject("WScript.Shell")
Set objEnv = shell.Environment("Process")
userName = objEnv("USERNAME")
Set userVar = shell.Environment("USER")
userVar("PV_OFF_SCREEN_SIZE_LIMIT") = 2048
MsgBox "Creo View PV_OFF_SCREEN_SIZE_LIMIT has been set to 2048 for "+userName+". For the new setting to take effect, close and re-start Internet Explorer."
Try using the environment variable PV_OFF_SCREEN_SIZE_LIMIT and set it to value 2048
That is what the lines I posted above does.  And it's easier for the user to double-click a .vbs file than to give them instructions of where to put it.  🙂
We have seen this issue in the past on XP...  You didn't indicate what OS you are running.  Here is what we used to fix it:
To disable graphics hardware acceleration:
  1. Choose Start > Control Panel.
  2. Double-click Display.
  3. Click the Settings tab.
  4. Click Advanced.
  5. Click the Troubleshoot tab.
  6. Move the Hardware Acceleration slider to None.
  7. Click Apply and then click OK to accept the new setting and close the dialog box
  8. Click OK to close the Display Properties dialog box.
  9. Restart Windows.
