Creo View Insufficient memory error
  • June 16, 2026
  • 95 views
I am using Creo View Release 8.0 and Datecode8.0.0.0 When I open .pvz file larger than 500MB in Creo View Lite 8.0.0.0 Build 27, I get an out-of-memory error, even if the memory limit for the Lite version is 16GB. The error appears immediately after I see the 3D model fully loaded. With the same file my colleagues have no loading problems. They use the same version of Creo View Lite. Here are the errors that I faced: Insufficient memory Creo View Lite has reached its maximum memory limit and will be closed. To view the data, use a version of the product with the Massive Assembly license option. Original, in italian: Memoria insufficiente Creo View Lite ha raggiunto il limite massimo di memoria e verrà chiuso. Per visualizzare i dati, utilizzare una versione del prodotto con l'opzione di licenza Massive Assembly.
Memory limit increase in Creo View was introduced with Creo View 11.0 onwards. Refer Increase Memory Limit for Creo View Lite and Express From 4 Gb to 16 Gb
So I would recommend updating your version to latest supported version.
Memory limit reach you observe in current release can be because of multiple reasons like usage of high end render modes like Shaded with Edges etc.
