7-Bedrock
February 2, 2022
Creo View - Touchscreen missing features
  • February 2, 2022
  • 2 replies
  • 1785 views
In the last few days I have been studying the possibility to run creo view on a touchscreen computer.
However I am not capable to use the feature to transform a part (translate or rotate) nor to select by window. It just seems that the equivalent function left click and drag of the mouse is not supported in touchscreen.
Is it possible to clarify if this is possible to do using a touchscreen?
Also, Is it possible to select part, one by one using touchscreen? Equivalent to Ctrl+left click
Thank you in advance.
Best answer by BF_10197348
About the gestures (http://support.ptc.com/help/creo/creoview/en/index.html#page/creo_view%2FWorking_with_Touchscreens.html%23wwID0E43GM)
I believe what I really need to know is the difference between  the "Multi-select parts" gestures and the "Spin" gesture you can see in the link above.
Thanks.
BF_101973487-BedrockAuthorAnswer
7-Bedrock
February 2, 2022
Thanks.
