Dimensions in sketch mode of creo 3
  • October 30, 2016
  • 8 replies
  • 5787 views
I have installed the Creo 3 student version. But i get no dimensions in sketch mode. Someone has got a solution for my problem or is this a restriction of the student version?
Best answer by davehaigh
You can tell if it's a graphics issue by putting this line in your config.pro:
graphics win32_gdi
If the issue goes away with that setting, it's an issue with your graphics card.
2-Explorer
October 31, 2016
It is most likely a graphics card problem or graphics card driver problem.
What computer, OS version, graphics card, are you using?
lmeding1-VisitorAuthor
to dschenken:
I use WIN10 with an old Intel Core 2 Quad Q6600Prozessor and a HD5450 graphic Card.
I think i will update my hardware the next month.
to MartinHanak:
in the evening i will make a picture. If i start to sketch i could not see any dimensions. In the Option menue normaly it is possible to activate an Option to see dimensions in sketch mode. But i my case there is no such Option.
to David Haigh:
i will try your hint at the evening
please publish pictures reporting your problem.
MH
davehaigh13-AquamarineAnswer
graphics win32_gdi
Hallo,
seems to work.....why ever. I wrote your config.pro changes in even all config.pro i found in the ptc folder......
After that it works. But i do not understand why, because the option to activate dimensions was missing......there was no direct problem with the dimensions.
Another flakey issue with Pro-E . I've had this problem as well. The fix was to go to: File, Options, Configuration Editor, go down to the "Find" button at the bottom of the menu and type "dimensions" in the field and click "find now" You will see "Sketcher_disp__dimensions" as a result, Click it and then close without saving change. VoilĂ , your sketcher dimensions magically appear.
2-Explorer
October 28, 2017
That's an odd option to have. It's like a software editor that has an option to not display variables in the source code.
StephenW
It's a toggle. You can turn off visibilty of the dimensions, constraints, vertices, and grid under the view tab when in sketcher or in the ribbon under setup display when in an internal sketch.
Gives the impression of free sketching without constraints or dimensions for the free spirit types.
