EMRGENCY: "Markup object no longer exists" - Cannot save Annotation Set / PVZ
  • June 17, 2026
  • 52 views
I am currently working in Creo View 10.0.0.0 (standalone) and have an active session open with hours of unsaved work on a fairly large assembly in PVZ format (with sections, color coding, visibility states).
When trying to save the active view as an Annotation Set, I receive the following error:
Save Error: Markup object no longer exists
Symptoms:
  • The newly created Annotation Sets appear as black squares in the sidebar instead of regular thumbnails and are not loaded on double click.
  • In Windows file Explorer, the original .pvz does not update. Instead, temporary files like [filename].etb.~1~ are generated, indicating the save process aborts before the container is packed.
  • Using "Save As" for the .pvz to a new folder results in a file where the Annotation Sets are broken in the same way. The same happens when saving a copy as *.pvs.
Question: The session is still open and the visual state is intact in my RAM. Is there any known workaround to force-save this current state? How can I identify and isolate the specific broken markup preventing the save, or extract the annotation set data directly from the active session before closing the application?
From the error message that looks like it came from a Windchill connected session. It could be that the session has lost authentication. Can you work with PTC tech support to raise an incident then we could look into it.
