How to Create Illustrations in different language in Creo Illustrate
  • June 29, 2024
  • 9 replies
  • 2325 views
Hi Everyone,
I want to create illustrations in creo illustrate in  some other language.
Can someone guide me how to  go about it . I am using Creo Illustrate  10.1
Thanks in advance.
Aditya Gupta
Best answer by agarland
Yes, it is a manual process to export and import the xlif files unless you are using Windchill.
For Windchill there is the ability to have an updated xlif file automatically applied to the c3di.
About Managing Localized Text with Windchill (ptc.com)
Regards
Adrian
Article - "Creo View & Creo Illustrate: How to override the default User Interface language set on a Windows machine": https://www.ptc.com/en/support/article/CS96862
Catalina
Community Moderator
July 5, 2024
Hi @Aditya1702,
Please note that industry experts also review the replies and may eventually accept one of them as solution on your behalf.
Catalina
Community Moderator
Catalina | PTC Community Moderator
Hi @Catalina ,
We have raised a case for the same since we wanted to create annotations in different languages & not change the UI language.
I will update once we have a solution.
Thanks & Best Regards,
Aditya Gupta
agarland
Creo Illustrate does have a localization feature for notes in figures.
About Localizing Text (ptc.com)
This allows you to export an xlif file for processing in a external translation tool before importing the translated xlif back into illustrate.
Hi @agarland ,
Thanks for your response.
Its a manual process right?
First we have to export .xlff file and then manually translate all the text and then again import the file correct?
Correct me if I am wrong also, can this process be made auto?
Aditya Gupta
agarland
agarland16-PearlAnswer
Regards
Adrian
