Hyperlink Creo Illustate
  • July 25, 2022
  • 3 replies
  • 1951 views
Is it possible to add a hyperlink in a callout in creo illustrate ?
Best answer by VladimirN
Article - "How to define hyperlinks or hotspots in Creo Illustrate": https://www.ptc.com/en/support/article/CS130375
VladimirN24-Ruby IVAnswer
Hi, you cannot set this to solved, when the referred article says there is no such function in Creo Illustrate!
This is misleading/a waste of time for any user.
Please correct or at least add a link to "is in work in product development etc."
Besides that why is there an option in the save as SVG called "Include hotspots for callouts"...
Kind regards
Tim
This is quite a problem; I’m also trying to work out how to do this for a client. A software engineer colleague of mine has partially resolved it by adding some JavaScript, but the client would also like the individual components in the shaded images to be highlighted and clickable. They currently use SolidWorks Composer, but as they have Creo Parametric, they’d like everything to be the same so they can open native Creo files... Unfortunately, this is a major limitation.
Translated with DeepL.com (free version)
