Import constraints from Creo parametric to Creo Illustrate
  • February 6, 2014
  • 3 replies
  • 2031 views
Hi all.
I have an assembly in Creo parametric containing a pin-connection between two parts. The one part is able to rotate around the other, with the pin-connection as pivot point.
Is it somehow possible to maintain this connection when importing the assembly to Creo Illustrate, and use it when repositioning parts here?
Best regards
Esben Oxholm
Esben Oxholm Bonde wrote:
... Is it somehow possible to maintain this connection when importing the assembly to Creo Illustrate, and use it when repositioning parts here?...
Best regards
Esben Oxholm
No, you will need to re-set the connection in Creo Illustrate.
Okay. Thanks for the answer...
Too bad it is not possible. Would save a lot of time.
Esben Oxholm wrote:
... Would save a lot of time.
Agree.
