Improve Creo 3
  • July 21, 2015
  • 11 replies
  • 3225 views
Improve Creo
Every new Pro-E/Creo release was worse than existing one. Creo 3 is worse than Creo 2. I will present just several observations:
1. All command icons are pale, harder to see.
2. Many changes are made just for sake of chamges. Typical example is edit definition, instead of text now there is a icon. This is really big change, but I dont know why?
3. Creo persistantly changes dimension on its own in sketch mode. You save sketch re-open it and dimension is changed by Creo. Dimensions are created by Creo in weird way, not enginering way.
4. Colors are horrible and do not match at all.
5. Scroling in work space is erratic not continous and smooth
6. Is it possible to calm down that zoom jumping all over the screen.
7. When you select file in work space and want to o it again searching for another file is it possible to go back to last selected file?
8. When you open constrains window that window completely covers three default part planes (Top, side and front) you can't select these planes to put constrains. Creo 2 did not cover first letter but Creo 3 does cover completely.
10. Creo 2 displayed all ocnstrains in window Creo 3 displays only 3, you must scroll down to select additional constrains. This results in hundreds of new mouse clicking.
11. New printing is a mess
12. Selecting and highlightning parts in assembly is more difficult than in Creo 2 that was already pretty bad.
13. Some dimensions are displayed with 3 and some with 3 decimals
14. It is very bad idea to have diferent C# for drawing and part. In Pro-E when you cerate drawing it automaticaly takes C # of the part. This is horrible mistake creating two diferent C #.
15. Try to pick dimension inside part it is almost impossible.
17. All our flexible parts as springs and bellows are " exploding" when you isert them to assembly. These are the same part that we used in Creo 2 and did not have these problems. These parts lose constrains when you open assembly that was sucessfule saved and checked in.
All in all it appears to me that you have people in charge to make Creo more user unfriendly, you are changing just to cange to be able to force us to take trainings and pay for this. Every new release just re-shufle everything withou any common sense just to be able to name it new release.
I am Pro-E/Creo used for more that 10 years.
Thanks Zlatko Salihbegovic
18-Opal
August 30, 2016
How about we try the political route: PTC is discriminating against tabs.  PTC is dictating that one tab doesn't have rights to select contents from another tab.  Equal Tab Rights and Equal Tab opportunities for equal selection!  Just let us select it!
