'Internal Error (005) occurred. Use the Check Database tool and contact technical support for assis
  • April 6, 2023
  • 2 replies
  • 2156 views
I am using Creo Schematics Release 7.0 and Datecode7.0.0.0
(.dge) I get the following error message when I try to open the data
'Internal Error (005) occurred. Use the Check Database tool and contact technical support for assistance.'
Here are the errors that I faced
Best answer by VladimirN
Article - "In Creo Schematics portshape graphic of a variable connector cannot be replaced when it has instances, either in the catalog or on a sheet": https://www.ptc.com/en/support/article/CS201447
VladimirN24-Ruby IVAnswer
thank you.
Isn't this also resolved in Creo Schematics7.0?
I can open it fine but another user has this problem
