Is there a fine zoom/coarse zoom option in Creo Illustrate?
  • July 11, 2016
  • 6 replies
  • 3234 views
neal lewis
agarland
Currently there's only the one zoom with no options to adjust the granularity.
For more controlled zooming i would try using the 'Zoom Window' option (ctrl+shift+z).
Is it particularly large or small models you are working with which would be helped by having a more controllable zoom function?
nlewis1-VisitorAuthor
Adrian,
Thanks for your reply. I use Creo® Illustrate in a manufacturing setting as a Technical Writer. We get very large models of Agricultural equipment that we need to be able to zoom in and zoom out. The views we make are used to illustrate manuals and assembly instructions.
I would guess that part of my problem is that I use a "non-standard" input device; a trackball. It is possible that I could adjust the ring to give finer control, but at the present I do not have the information that tells me how to do that.
What I wind up doing is getting a view slightly smaller than what I want, exporting it, and then manipulating it in Adobe Illustrator - which does allow for finer work.
Neal Lewis
3-Newcomer
July 12, 2016
my colleagues use 3Dconnexion SpaceMouse. They can some much "softer" than with the mouse wheel. But I dont konw if it's a driver feature or the device.
br Bernhard
