Move Order of sBOM Items?
  • December 16, 2014
  • 0 replies
  • 1078 views
Is it possible to change the order of sBOM items?
I've created about 75 sBOM entries, but I'd like to change the order. For example, the item which is currently in 35th place I'd rather have in 20th place (all others in their current sequence).
I know that I can select the 35th item, cut it, go to the top assembly and click place. That puts it at the very end. I would then have to go through that process with all the items that should be below that item, but that is incredibly painful.
Similarly, if I've made one item a child of another, is there a way to "simply" move it to the left so it's on the same level?
There's got to be a better way!
Thanks in advance,
Tom Burton
