9-Granite
September 19, 2024
Question on Creo Schematics
  • September 19, 2024
  • 3 replies
  • 857 views
Hi Folks,
I have few question related to Creo schematics as below.
1. How to restrict the terminal connections? is it automated or manual?
2. How to show the component label in 2Dschematics & 3Dcabling?
3. Real time mass of Harness?
4. Do we get the branded or industry standard catalogues like wise TE connectivity with 4 connection ports?
5. How to we customize of create our own catalogue in schematics?
It would be really helpful to get the answers for the above questions with specific examples if possible.
TIA
Naresh
Hi NJ_10652808,
Short answer; Manual process depending on how you set it up. Datasets can be created and applied which then restricts based on the dataset. Caveat is that it locks the library file so you are required to remove the dataset if you need to edit it (using a lock design file). The help that comes with Schematics has several good examples. Not sure. Can be in a dataset added to the component(s). We had to build our own- a sort of long process. In the help on schematics gives some examples for creating the library shapes. There are some videos online that shows some details as well.
Kenneth Littlejohn
Eng System Admin | G&W Electric
305 W. Crossroads Pkwy, Bolingbrook, IL 60440
P. +1 708-297-3648 ext. 3648 | www.gwelectric.com
upload_-MS5wbmc=-2376677843082938002..pngupload_-MC5wbmc=-4835827729254613410..pngupload_-My5wbmc=-4840512935871531584..pngupload_-Mi5wbmc=-4718284003672284335..png
Catalina
Community Moderator
September 24, 2024
Hi @nj_01_10652808,
If so, please mark the appropriate reply as the Accepted Solution or please feel free to detail in a reply what has helped you and mark it as the Accepted Solution. It will help other members who may have the same question.
Please note that industry experts also review the replies and may eventually accept one of them as solution on your behalf.
Catalina | PTC Community Moderator
NareshJ9-GraniteAuthor
9-Granite
September 26, 2024
Hi Catalina,
I am not happy with the response. I am looking in more details on the queries.
Naresh
