7-Bedrock
July 9, 2026
Questions about using markup features in Creo View Lite
  • July 9, 2026
  • 3 replies
  • 127 views
Hello PTC Support,
I would like to ask for advice about the markup features in Creo View Lite.
We open PDF drawings stored in Windchill using Creo View Lite, and we would like to use the markup function to add comments and feedback for the drawing creator.
However, we are having some difficulty with the usability of Creo View Lite, so we would appreciate your advice.
The issues are as follows:
  • When using a PC with a mouse and keyboard, it is difficult to place an annotation exactly where we want it. Also, the annotation window is too small.
  • When using a touch panel monitor, we want to draw lines on the drawing, but the operation is recognized as scrolling instead, so the drawing on the screen moves.
  • We would like to write Japanese comments that require two or more strokes. However, when using the freehand tool, the input is finalized as soon as we release the mouse button or lift the pen/finger. Therefore, it seems that we can only use the “Annotation” function for comments.
Could you please advise us on the following points?
  1. How do other Creo View users typically use the markup function for drawing review?
  2. When reviewing drawings, what kinds of devices do users generally use? For example, mouse and keyboard, pen tablet, touch panel monitor, etc.
  3. Is there any recommended setting or operation method to make annotation placement and freehand input easier?
  4. Is it possible to create freehand comments with multiple strokes, especially for handwritten Japanese text?
Thank you in advance for your support.
Best regards,
Tomoko Tanazawa
creoviewのマークアップ機能について教えてください。
windchillに保管されたPDFの図面をcreoviewLITEで開き、マークアップを使って
作成者にコメントを書き入れてフィードバックしたい
ただ、creoviewの操作があまりよくないのでアドバイスしてほしい
・PCだとマウスとキーボードで入力するんだけど、「注釈」を追加するときに
 思ったところに注釈が作れない。注釈ウィンドウが小さすぎる
・タッチパネルモニタで操作しようとすると、線を書き込みたいのにスクロール判定されて
 画面上の図面が動いてしまう
・2画以上の日本語を書き込みたいのに、フリーハンドだと手を離すと確定されてしまうので
 コメントする場合は「注釈」しかない
1.creoviewをお使いの方はどのように使用されているか
2.検図をするとき、皆さんはどのようなデバイスをお使いでしょうか
agarland
Could you share a video of the workflow when trying to add a annotation on the desktop, this would help us understand the issue you are experiencing.
A video showing the touch device issue would also be good if you are able to create one.
Currently the freehand tool only allows one line to be created, I would suggest creating an idea to enhance it to allow multiple lines without having to activate the tool again.
Regards
Adrian
Tomoko_T7-BedrockAuthor
7-Bedrock
July 15, 2026
Thank you very much! I'll share the video once I've taken it, so please give me a little time.
