RE: Document CS94057
  • November 17, 2015
  • 975 views
I am trying to fix the issue of drawings printing black from Creo viewer.  I am looking at Document CS94057 and under the workarounds section, it says
  • Set PV_OFF_SCREEN_SIZE_LIMIT=2048 as a System Environment Variable in the Creo View runtime environment
Where can I find the System Environment Variable in the Creo View runtime environment?
Alyssa
from windows start menu, select computer
from top menu bar of new window, select system properties
from the nav pane (left side) select advanced system settings
in the new window, under the advanced tab select the button environment variables
this is where you can manually create your environment variables.
This is usually accomplished using a batch or start up file
