Requirement in animation
  • September 11, 2012
  • 1640 views
Hello everyone
Actually I am preparing a presentation of clutch asm and its working , which is to be explained in college classes later.
So I want to create an animation video to add in it in order to make more understandable and illustrative.
I have created the asm and here is the link.
http://communities.ptc.com/docs/DOC-3014
In animation, I have 2 requirements
• It must contain section view in between the working so that I need not to hide any component.
• Clutch discs must be triggered to rotate and stop while CFD (clutch friction disc) touch them or separate.
I have defined collision detection between some parts and it doesn't complete the 2nd requirement. Therefore any constraint or mechanism feature may be required.
If any constraint requires modification for these purposes , please tell and add the updated model.
There are many videos on youtube but I want to prepare by Creo parametric. Till now I have made this animation too.
http://communities.ptc.com/servlet/JiveServlet/download/3014-1-42314/Clutch-explode.mp4
So it is not all about the presentation, it is about the new things I will learn in Animation.
is it possible with illustrate?
Thanks.
Working Clutch animation finally made
http://sdrv.ms/TtliC8
