Saving object color information to a PVZ file
  • March 17, 2026
  • 123 views
When using Creo View (MCAD) if various faces of an object have been recolored using Home --> Appearance -> color palette,  it it possible to save the recolored object to a PVZ file in such a way that the new color information is retained in the file and again displayed when the PVZ file is reopened?
Best answer by BillRyan
The trick is to get the saved colors into an annotation set, (use save annotation set).  The saved annotation set will also store repositioned components if you translated them.
BillRyan16-PearlAnswer
