Sheet metal Flat sketch not updated
  • July 9, 2013
  • 1094 views
Hi All,
When we access the sketch geometry of a flat geometry it is not coming correct, sketch coordinate gives random value. sketch is not updated correctly. when we open the sketch manually and running the program again it comes correct. Any one can suggest what API is required to correct the situation without physically opening and correcting the model.
Joseph
Few more cases the same problem occurs, but when the sketch manually openend and closed it resolves.
