3-Newcomer
February 1, 2023
SVG hidden construction geometry
  • February 1, 2023
  • 5 replies
  • 2374 views
I have an issue with saving as illustration file, namely as a SVG file.
The problem is that I have some surfaces and cosmetics in the model construction geometry in the C3DI which do not show in the SVG file, I tried checking the filters in the options (current figure and illustration) and the different SVG options and looking for the answer on your website without luck.
Best answer by agarland
All constructions are excluded from the HLR generation, so the behaviour you are seeing is expected.
This is done because in most scenarios' construction geometry is there for exactly that purpose 'construction' and is not expected to be seen in the published illustrations.
If you have a use case that requires the construction geometry to be seen in the published output, I suggest creating an idea on the forum so other users can vote for it if they also have a similar requirement.
Creo View / Illustrate / Schematics Ideas - PTC Community
Please specify which version of Creo Illustrate you are using.
3-Newcomer
February 1, 2023
creo illustrate 9.0
agarland
agarland16-PearlAnswer
3-Newcomer
February 2, 2023
Thank you for your quick and clear respons.
