Terminator table lock up when importing into CREO Schematics
  • July 18, 2025
  • 2 replies
  • 451 views
I am having issues with importing a term table .csv file into Creo schematics 7 and unsure where to look or correct on the issue.  The table seems to work fine with 1467 entries and seems to start having issues of not loading and locking up schematics when additional entries are added beyond that.  I am also uncertain if any blank cells have to have an entry of UNSET or if they can be left blank.
Is there a limitation on the number of SET columns that can be created.
Any advice or suggestions would be helpful.
Thank you,
Scott
Hello Scott,
• as far as i know there is no limitation on number of entries in TT. I'm able to load suceccfully table with 2277 entris (differnet rows) and 15 columns ... check entry 1468-maybe there is some mistake or redondent comma ...
• in addition , since eventally it is a table - in case you have large number of columns , try to reduce the number of columns and check if it can be  imported .
• you can leave blank cells , but notice that in Creo Schematics "UNSET" can be also paramter value or indiacation that the paramter was not set with any value .
• there is no limitation on how many SET columns you have in the table
Community Moderator
August 12, 2025
Hi @Scott_Zaske,
Anurag
