Unit of Measure In Creo 2.0
  • September 4, 2012
  • 7 replies
  • 7578 views
How to you change from mm to inch in Creo View 2.0
Open the part or assembly and go to File/Prepare/Model Properties/Units - change
There are some config options pro_units_length and pro_units_mass
The idea is that you want to open templates that are already set the way you want, but File/Prepare/... will let you change it.
canderson10-MarbleAuthor
Sorry left off an important detail... CREO VIEW 2.0
D'OH!
Anyone here know how to change the default/startup units from inches to mm. WITHOUT uninstalling the software and re-installing it.
Dale_Rosema
David,
Take a look at this post:
http://communities.ptc.com/message/188248#188248
Thanks, Dale
Check this out http://bit.ly/1eHupI3
Madhavi
