Use the environment variable "HOME" to costumize the User Interface
  • July 29, 2013
  • 3 replies
  • 1529 views
In the old ProE environment it was possible to use the variable "HOME" to set the the path for the login-ID. In this way ist was possible to make a configuration for the users in this folder. With the start of ProE were this configuration used to create the interface. For the new UI-File this configuration is not possible.
Dale_Rosema
You may want to vote on your own idea.
And on this one:
http://communities.ptc.com/ideas/2713
Thanks, Dale
Hello Dale,
what is this link. I cann't open it.
regards Sebastian
Dale_Rosema
Should be fixed now.
There's another idea that was added so links would be posted correctly, but I don't remember which one that was.
