3d Model Annotation MBD
Is there a setting in Creo view to enable the 3d model annotation to be visible?
vdegaonkar
3D model annotation Visibility is controlled through two different things:
  • Home >> Display >> Filters >> Model annotations >> select Planar, Screen & Floating annotations check box and apply to active or all views.
  • Annotation visibility is also controlled through view states. so to view a complete MBD View, activate view state from Primary Panel >> Viewables tab and double click a view state.
Hope this will help, if not please provide more details on exact issue that you are facing.
