Anyone here convert from Pro/E (Parametric) to .PVZ file? PTC removed PVZ
WHY PTC? Why!??
I use Isodraw for illustration, and Isodraw 7.1/7.3 does not open*.ASM files. nor Parametric exports PVZ files.
WHY PTC? Why!??
thanks for the heads up PTC.
FYI - IsoDraw is sold in two configurations:
- IsoDraw Foundation (for 2D drawing) with the option of adding
- IsoDraw CADprocess (3D Extension) which supports the import of 3D CAD data
Perhaps when you purchased the application, you were unaware of the differences. You may want to have your manager contact your sales rep to upgrade your license.
With kind regards,
Rick
Chi-WeiHo1-VisitorAuthor
um, it's Creo 2.0, they stripped all the functions.
my Isodraw is the same.
We just switched (on Monday actually) from IsoDraw 7.1 which we used with asm files to 7.3, f00 and are again using asm files.
Can you attach a screen shot of the following window? Open IsoDraw, go to Help > About IsoDraw... (last option in menu).
In Creo 2.0 go to "Save As", "Save a Copy".
