7-Bedrock
Assembly fails to publish
Hello all,
I am facing the problem to publish some assemblies.
Error - Timeout Error
I gone through with some of the article for the same issue and troubleshooted by increasing the time from 3600 secs to 7200 - 10800 secs in WVS.properties file. But still assembly is failing with the same error. We are using monolithic environment and have 2 creo worker.
What can i do to publish the assemblies succesfully.
Any help would be much appreciated.
Windchill Version - 12.0.2.7
Creo Version - 8
How many required objects are in the assembly?  Can you open master rep in client side of Creo Parametric and use save as -> PVZ?
Another check that we always do is to open the file in Creo Parametric make make sure that it opens without any human interaction needed. If it gets a pop up for some type of human interaction, then the same thing will happen on the CAD Worker , thus causing a timeout error.
Catalina
Community Manager
Hi @Rahul_Rathore,
If so, please mark the appropriate reply as the Accepted Solution or please feel free to detail in a reply what has helped you and mark it as the Accepted Solution. It will help other members who may have the same question.
Please note that industry experts also review the replies and may eventually accept one of them as solution on your behalf.
Catalina | PTC Community Manager
