7-Bedrock
Can I update a PVZ file with new engineering changes in creo view?
So I have marked up a model with annotations and notes.
The engineering has recently updated from rev A to Rev B.   Is there a way for Creo View to update the engineering while still keeping the annotations and groups of the previous version.
Or is there a compare function I could do that would compare part numbers vs the location and have another PVZ of the changes B had to tack on to Rev A?
"copy forward" is the functionality you are looking for to bring the annotation forward as the model iterates/revises.   Manually manage it as shown in image below.  I don't know if you can compare a model with markups...
2022-10-31 14_26_29-Assembly - jt_applications-assembly.asm, A.32 and 3 more pages - Work - Microsof.png
7-Bedrock
So I have to release It to windchill and that function actually happens through windchill then and not in Creo view itself?
Thanks for your reply 🙂
What is your process for Creating the PVZ file at Rev A and for Rev B?  We use Windchill publishers to create all Creo View content.
