Convertion: IsoDraw 3D ISO -> Creo View PVZ -> Creo Illustrate C3DI
- 5 replies
- 5164 views
- Translate All
Hello!
I try to carry out following actions:
1. I have a 3D ISO file from Arbortext IsoDraw 7.1 M070, which contains some 3D assembly.
2. I upload this 3D ISO file into Creo View MCAD 1.0 M030, and then save it in a PVZ format.
3. If you try to import the PVZ file into Creo Illustrate 1.0 M030 (by using "Import" -> "Embed" option) it displays only the structure of the assembly, but does not have the 3D model in the working window
. But at the same time, the PVZ file can be opened in Creo View Express, and everything is OK here. Is this a bug?
