Aug 29, 2014 7:48 PM UTC
Creo Illustrate 2.0 - Annotations button
Hello
Some days ago I started working with Creo Illustrate 2.0 M040 and from first moment after installation my Annotations button is unactivated.
Does anybody know what might be the reason?
Sep 5, 2014 11:41 AM UTC
Wojciech,
It sounds like your callouts template file might have become corrupted. I suggest you delete (or move) your CalloutTemplates.xml file and restart Creo Illustrate to regenerate a new template.
Your CalloutTemplates.xml can be found in:
%APPDATA%\PTC\Illustrate
Sep 5, 2014 12:32 PM UTC
Hi Tim
I removed the CalloutTemplates.xml file, but after restart Creo Illustrate, the Annotations button still remains inactive.
Sep 5, 2014 12:57 PM UTC
Wojciech,
In that case it might be your user_prefs.xml that needs a refresh. Same location; delete (or move) your user_prefs.xml and start Creo Illustrate to refresh this.
Tim
Dec 10, 2014 11:31 AM UTC
Hello for everyone
The problem was related with the license.
With the new license this problem does not appear.
