Creo Illustrate, Different line thicknesses when exporting an image with/without Page-Setup
- 7 replies
- 5709 views
- Translate All
unfortunately I have a next problem:
I just noticed that when I export images, the stroke widths are different when I make a display with and without page setup.
So far I have always exported images by fixing the model in the window and then setting the desired image width (e.g. 17.5 cm) with resolution 300dpi (118 dots per cm) when exporting. The result is an image with a pixel width 17.5cm x 118dpcm = 2065 pixels.
In the meantime I found out that it is more convenient to define a page size. And that you can define your own page sizes with the administration tool. So I defined a page with the dimensions 17,5x11cm and set it later.
When exporting the image I only had to set the resolution 118dpcm and I also got an image of the pixel width 17,5cm x 118dpcm = 2065 pixels.
So both images are the same size in the result. For both images the pen thicknesses Thick = 0,2mm and Thin = 0,1mm were set.
Problem:
The exported line thicknesses are different. The exported image with the predefined page setting 17,5x11cm has unfortunately much too thick lines.
Questions:
Am I doing something wrong?
I would like to work with page settings and have the line thickness I get when I export without page setup. What to do?
