Creo Illustrate export formats
Dear community, is it possible to export from Creo Illustrate to the format JT?
I've seen there is an add-on for Parametric that adds the JT export format. Can it be done also with Illustrate? Or is it something that can be implemented worker side in windchill?
We have the necessity to export in this format and we would like to explore the possibilities, if any...
If I export in IGES or STEP, is there a recipe file to be edited in order to define export preferences?
Thanks in advance
agarland
agarlandAnswer
The JT filter is a separately purchasable option which allows you to import & export JT file format.
Please refer to the Technical Graphics Compendium
Also:
Article - CS115565 - How to Install the JT Import Filter in order to open & import JT file format in Creo View & Creo Illustrate (ptc.com)
agarland
agarland16-PearlAnswer
Also:
AndreaT14-AlexandriteAuthor
Thank you very much @agarland
And what about editing recipe files (aside for the ones for pvz publications) for export formats? Is it even a real possibility or just my immagination? 😅
