Creo illustrate-Fade out error
I wanted to ask regarding the fade out feature. So while animating I used the fade out feature and it worked initially, after I ran the animation again whenever I fade out my parts they go into the 'wireframe' appearance instead of disappearing. Also, I checked the transparent % and it was at 0% but it still looks like the picture I shared below.
Thank you.
agarland
agarlandAnswer
Could you give some more details, what version of illustrate are you running, what render mode is that etc.
Obviously this shouldn't be happening, so I would suggest contacting tech support and logging a case so we can investigate the cause properly.
agarland
agarland16-PearlAnswer
This is Creo Illustrate 11.0 render mode is white shaded illustration. I will log a case then with tech support.
