Creo Illustrate fly-through?
Is it perhaps possible to "move through" a part/model in Illustrate? For example, let's say you have a model of a gun turret and you want to do a fly-through, first showing the outside and then the inside of the turret, is it possible to move the camera view through the outside of the turret to take shots of the inside? Has anyone tried doing fly-throughs using Illustrate?
Thanks!
rgrobler1-VisitorAuthor
Ah you have to select Perspective view mode under model options!
