Creo Illustrate - missing surfaces & sketch lines
Creo Illustrate files doesn't show surface models & sketched lines generated from Creo data. Only solid models are visible. Is there a setting I need to check to be able to show this data in Illustrate?
agarland
The first place to check is Options>Illustration>Model>Filters
All model geometry is checked, but surface parts & sketches are not visible in Illustrate.
