Ramon_Bohne
Creo Illustrate, Render image shift @ 2D figure
Hi all,
sometimes I get a render image shift (displacement) on the 2D figure (see attchement). Any idea why?
Until now I could allways move the render image back into its correct position and everything is fine. But solving the problem would be my prefered way 🙂
Thanks a lot and best regards
Ramon Bohne
agarland
Hi Ramon,
When does this 'shift' happen?
Is it while you are working in the 2D figure or is it generated this way?
Regards
Adrian
Ramon_Bohne
It is generated. But only sometimes.
Thx and best regards
Ramon
agarland
I have not seen this issue before, so can't give any clues as to why it happens I'm afraid.
I would be keen to understand what causes it though, so if you would be able to contact tech support the next time it occurs and (if possible) share the file before you've fixed the issue that would help us investigate the issue.
Regards
Adrian
