Creo illustrate - View status problem
I'm trying a trial version of Creo Illustrate standard.
I'm working with a very large assembly, i created the pvz file with creo then imported it with Illustrate, everything seems OK, the parts that were hidden in Creo are not visible. But, when I start creating sequence steps, the hidden parts start showing up.
Anyone with this problem?
agarland
Could you give a bit more detail on the steps you are taking to create the sequence?
It's hard to fully understand the issue from your description, any info you can give could help.
