Creo Object Toolkit C++ with Creo Illustrate
I'm exploring the idea of automatic view creation, where a program would intake a part number of an assembly, highlight it, and export a capture of that part in the assembly and potentially create a view of it. In order to do this, the following would need to be possible:
  • GUI-less API integration with Illustrate
  • API-enabled Camera manipulation
  • API-enabled Part search and manipulation (highlight, color, transparency)
Are any of these possible within Illustrate? Which APIs can work with Illustrate (Web.Link, J-Link, C/C++ Toolkit)?
Best,
Charlie
VladimirNAnswer
Article - "Is there any API-interface for Creo Illustrate": https://www.ptc.com/en/support/article/CS125540
Quote: "No API is available for Creo Illustrate. This functionality is covered by Idea "Add API/Toolkit functionality to Creo Illustrate": https://community.ptc.com/t5/Creo-View-Illustrate-Schematics/Add-API-Toolkit-functionality-to-Creo-Illustrate/idi-p/905602 "
Community Moderator
Hi @CD_14428108,
Thank you for your question.
Anurag
VladimirN24-Ruby IVAnswer
