Creo View 2.0 Question
When creating an annotation in Creo View, using the Markup Tab, I wonder if
there is a setting to change how the selection and de-selection works. Current
functionality is that if I am adding multiple freehand lines to a drawing, I
select freehand and draw my line. I then need to go back up to the freehand
icon and click it again to create another line. Is there a way to set the
system so I can create multiple lines, without having to go back to the ribbon
all the time? Note: this is the same for Notes, Leader lines, and Shapes.
I didn't see a way to do it. It would be nice if copy/paste function worked for these features. Some of the icons in the ribbon have <ctrl> + <key> functions like search. A repeat in the RMB pop-up would be nice too! I'd recommend placing an enhancement if nobody has an answer.
As a sidenote. If you follow Creo on Twitter, you will notice that Madhavi is creating many tips and tricks for common functions inCreo View.
