Creo View 3.0 preferences and customization
Hello everyone,
I' m realy struggeling with the customization of creo view 3.0 for our users. For the preferences I'm using the *pref.xml files like shared_pred.xml.
But how do I get the pvlite_customization.ui shared for the clients?
Thanks in advance,
Fred
gkochAnswer
2-Explorer
There is a rather detailed article about configuring the UI of Creo View 3.0 - maybe it helps:
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS152679
gkoch2-ExplorerAnswer
2-Explorer
Thank you so much for the link, it helped me so much. But can you help me once again please?
If you want the .xml and .ui files to be located at a shared location you name them (in my case for pvlite)
shared_cust_pvlite.ui
shared_prefs_xml
and put them at a shared location. But how do I tell CreoView where this shared directory is? I have no idea.
Thanks in advance again for helping me,
Fred
Frederik,
I guess that you have to copy .xml and .ui files from shared directory to local disk before you start Creo View.
Martin Hanak
