Creo View 8 Unable to access the Animation functions.
I am using PTC Product View (Formerly Creo View) Release 8.0 and Datecode 8.0.0.0 I am unable to access the Animation Advanced function when working in the MCAD Creo View mode. I get a message that says "The Animation (edit) license is not available at this time"
6-Contributor
Creo View Animator is a separate license that needs to be purchased and available. It is not included with the MCAD license alone.
SPN-2449-F- Creo View Animator - Registered User
Feature Comparison of PTC Creo View MCAD
Animation is listed as an MCAD capability with an *Asterix* - *Features require additional Creo View module(s).
SPN-2426-F- Creo View JT Format Option
SPN-2435-F- Creo View MCAD Registered User
SPN-2437-F- Creo View MCAD Concurrent User
SPN-2440-F- Creo View Design Check - Registered User
SPN-2441-F- Creo View Lite
SPN-2447-F- Creo View Design Check - Concurrent
SPN-2448-F- Creo View Interference Analysis - Registered User
SPN-2450-F- Creo View Interference Detection Engine
SPN-2453-F- Creo View Interference Analysis - Concurrent User
SPN-2454-F- Creo View Animator - Concurrent User
SPN-2455-F- Creo View Massive Assembly Option Concurrent User (Included with Creo View 12)
SPN-2456-F- Creo View Massive Assembly Option Registered User (Included with Creo View 12)
SPN-2820-F- Creo View ECAD Suite
SPN-2820G-F- Creo View ECAD Suite - Global Floating
SPN-2821-F- Creo View ECAD Suite - 1 Country Floating
6-Contributor
Phillip113-AquamarineAuthor
Thank you ​@mgleason1983. I did not realize that. Excellent information.
