Creo View - Envelope (Measurements) and orientation control
- 2 replies
- 1380 views
- Translate All
Hello everyone,
I'm not an expert Creo View user and I'm trying to find a way to obtain the minimum-size enclosure that contains a Creo part or assembly (or imported STEP files). In Creo Parametric you can set the Enclosure feature to "optimized" (from 11.0) or orient it according to a selected CSYS.
I couldn't find a similar option in Creo View: when using Markup > Measurements > Envelope, the bounding box is always created according to the default CSYS. In the attached picture you can see a practical example where my part's CSYS is not oriented according to the minimum-size envelope/enclosure.
Am I missing something? Thanks.
